Time Before: 0.02104 seconds
Time After: 0.02750 seconds
Time Taken: 0.00646 seconds
Time Before: 0.02761 seconds
Time After: 0.02804 seconds
Time Before: 0.02827 seconds
Time After: 0.02842 seconds
Time Before: 0.02922 seconds
Time After: 0.03181 seconds
Time Taken: 0.00260 seconds
Time Before: 0.02847 seconds
Time After: 0.03592 seconds
Time Taken: 0.00745 seconds
Time Before: 0.04591 seconds
Time After: 0.04634 seconds
Time Before: 0.04953 seconds
Time After: 0.05107 seconds
Time Taken: 0.00154 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04524 seconds
Time After: 0.05130 seconds
Time Taken: 0.00606 seconds
Memory After: 2,261.820 KB
Time Before: 0.09973 seconds
Time After: 0.09988 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12189 seconds
Time After: 0.12332 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.13185 seconds
Time After: 0.13202 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13529 seconds
Time After: 0.13681 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788850378, location = '/forums/private.php?do=newpm&explain=1&u=108263' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.15945 seconds
Time After: 0.15969 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
