Time Before: 0.00194 seconds
Time After: 0.00245 seconds
Time Before: 0.00254 seconds
Time After: 0.00297 seconds
Time Before: 0.00319 seconds
Time After: 0.00332 seconds
Time Before: 0.00400 seconds
Time After: 0.00651 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00337 seconds
Time After: 0.01070 seconds
Time Taken: 0.00733 seconds
Time Before: 0.01330 seconds
Time After: 0.01374 seconds
Time Before: 0.01625 seconds
Time After: 0.01747 seconds
Time Before: 0.01226 seconds
Time After: 0.01774 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02553 seconds
Time After: 0.02570 seconds
Time Before: 0.02821 seconds
Time After: 0.02945 seconds
End call of global.php: 0.032582998275757
Time Before: 0.03424 seconds
Time After: 0.03453 seconds
Time Before: 0.03729 seconds
Time After: 0.03900 seconds
Time Taken: 0.00171 seconds
SET lastactivity = 1776464950, location = '/forums/private.php?do=newpm&explain=1&u=108273', badlocation = 1
Time Before: 0.05457 seconds
Time After: 0.05485 seconds
Page generated in 0.053637027740479 seconds with 9 queries, spending 0.0084128379821777 doing MySQL queries and 0.045224189758301 doing PHP things.
