Time Before: 0.00167 seconds
Time After: 0.00210 seconds
Time Before: 0.00217 seconds
Time After: 0.00259 seconds
Time Before: 0.00282 seconds
Time After: 0.00293 seconds
Time Before: 0.00384 seconds
Time After: 0.00657 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00301 seconds
Time After: 0.01115 seconds
Time Taken: 0.00814 seconds
Time Before: 0.01367 seconds
Time After: 0.01406 seconds
Time Before: 0.01668 seconds
Time After: 0.01784 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01295 seconds
Time After: 0.01802 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02373 seconds
Time After: 0.02386 seconds
Time Before: 0.02594 seconds
Time After: 0.02715 seconds
Time Before: 0.02996 seconds
Time After: 0.03011 seconds
Time Before: 0.03218 seconds
Time After: 0.03362 seconds
UPDATE session SET lastactivity = 1789124042, location = '/forums/private.php?do=newpm&explain=1&u=108280', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04842 seconds
Time After: 0.04869 seconds
