Time Before: 0.02091 seconds
Time After: 0.03294 seconds
Time Taken: 0.01204 seconds
Time Before: 0.03308 seconds
Time After: 0.03356 seconds
Time Before: 0.03381 seconds
Time After: 0.03397 seconds
Time Before: 0.03483 seconds
Time After: 0.03721 seconds
Time Taken: 0.00237 seconds
Time Before: 0.03408 seconds
Time After: 0.04138 seconds
Time Taken: 0.00731 seconds
Time Before: 0.05437 seconds
Time After: 0.05477 seconds
Time Before: 0.05718 seconds
Time After: 0.05863 seconds
Time Before: 0.05372 seconds
Time After: 0.05890 seconds
Time Taken: 0.00518 seconds
Time Before: 0.09342 seconds
Time After: 0.09359 seconds
Time Before: 0.11633 seconds
Time After: 0.11766 seconds
Time Taken: 0.00132 seconds
Time Before: 0.12852 seconds
Time After: 0.12869 seconds
Time Before: 0.13116 seconds
Time After: 0.13259 seconds
UPDATE session SET lastactivity = 1776751329, location = '/forums/private.php?do=newpm&explain=1&u=108289' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14959 seconds
Time After: 0.14993 seconds
