Time Before: 0.00133 seconds
Time After: 0.00201 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00210 seconds
Time After: 0.00252 seconds
Time Before: 0.00279 seconds
Time After: 0.00294 seconds
Time Before: 0.00373 seconds
Time After: 0.00600 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00299 seconds
Time After: 0.01102 seconds
Time Taken: 0.00803 seconds
Time Before: 0.01344 seconds
Time After: 0.01384 seconds
Time Before: 0.01653 seconds
Time After: 0.01774 seconds
Time Before: 0.01269 seconds
Time After: 0.01794 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02310 seconds
Time After: 0.02321 seconds
Time Before: 0.02512 seconds
Time After: 0.02633 seconds
Time Before: 0.03042 seconds
Time After: 0.03060 seconds
Time Before: 0.03343 seconds
Time After: 0.03492 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108305', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05089 seconds
Time After: 0.05126 seconds
