Time Before: 0.00372 seconds
Time After: 0.00475 seconds
Time Taken: 0.00102 seconds
Time Before: 0.00482 seconds
Time After: 0.00518 seconds
Time Before: 0.00544 seconds
Time After: 0.00572 seconds
Time Before: 0.00653 seconds
Time After: 0.00923 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00580 seconds
Time After: 0.01436 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01735 seconds
Time After: 0.01755 seconds
Time Before: 0.02086 seconds
Time After: 0.02212 seconds
Time Before: 0.01660 seconds
Time After: 0.02236 seconds
Time Taken: 0.00575 seconds
Time Before: 0.02810 seconds
Time After: 0.02828 seconds
Time Before: 0.03245 seconds
Time After: 0.03371 seconds
Time Before: 0.03883 seconds
Time After: 0.03904 seconds
Time Before: 0.04171 seconds
Time After: 0.04317 seconds
UPDATE session SET lastactivity = 1776493096, location = '/forums/private.php?do=newpm&explain=1&u=108310' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.06031 seconds
Time After: 0.06068 seconds
