Time Before: 0.01425 seconds
Time After: 0.01819 seconds
Time Taken: 0.00394 seconds
Time Before: 0.01829 seconds
Time After: 0.01894 seconds
Time Taken: 0.00065 seconds
Time Before: 0.01922 seconds
Time After: 0.01936 seconds
Time Before: 0.02021 seconds
Time After: 0.02229 seconds
Time Taken: 0.00208 seconds
Time Before: 0.01944 seconds
Time After: 0.02717 seconds
Time Taken: 0.00773 seconds
Time Before: 0.03293 seconds
Time After: 0.03319 seconds
Time Before: 0.03561 seconds
Time After: 0.03679 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03216 seconds
Time After: 0.03699 seconds
Time Taken: 0.00483 seconds
Time Before: 0.06398 seconds
Time After: 0.06417 seconds
Time Before: 0.07475 seconds
Time After: 0.07604 seconds
End call of global.php: 0.078223943710327
Time Before: 0.08242 seconds
Time After: 0.08262 seconds
Time Before: 0.08529 seconds
Time After: 0.08684 seconds
Time Taken: 0.00155 seconds
SET lastactivity = 1783233923, location = '/forums/private.php?do=newpm&explain=1&u=108334', badlocation = 1
Time Before: 0.10380 seconds
Time After: 0.10409 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
Page generated in 0.10274696350098 seconds with 9 queries, spending 0.0078258514404297 doing MySQL queries and 0.094921112060547 doing PHP things.
