Time Before: 0.00141 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00243 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00266 seconds
Time After: 0.00281 seconds
Time Before: 0.00346 seconds
Time After: 0.00636 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00286 seconds
Time After: 0.00971 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01212 seconds
Time After: 0.01257 seconds
Time Before: 0.01523 seconds
Time After: 0.01650 seconds
Time Before: 0.01143 seconds
Time After: 0.01668 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02202 seconds
Time After: 0.02218 seconds
Time Before: 0.02393 seconds
Time After: 0.02519 seconds
Time Before: 0.02814 seconds
Time After: 0.02831 seconds
Time Before: 0.03030 seconds
Time After: 0.03174 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108370', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04399 seconds
Time After: 0.04424 seconds
