Time Before: 0.00141 seconds
Time After: 0.00195 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00202 seconds
Time After: 0.00241 seconds
Time Before: 0.00271 seconds
Time After: 0.00286 seconds
Time Before: 0.00372 seconds
Time After: 0.00599 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00294 seconds
Time After: 0.00993 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01175 seconds
Time After: 0.01214 seconds
Time Before: 0.01342 seconds
Time After: 0.01462 seconds
Time Before: 0.01117 seconds
Time After: 0.01483 seconds
Time Taken: 0.00365 seconds
Time Before: 0.02006 seconds
Time After: 0.02017 seconds
Time Before: 0.04512 seconds
Time After: 0.04642 seconds
End call of global.php: 0.04889988899231
Time Before: 0.05033 seconds
Time After: 0.05048 seconds
Time Before: 0.05352 seconds
Time After: 0.05498 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108372'
Time Before: 0.07030 seconds
Time After: 0.07059 seconds
Page generated in 0.069379806518555 seconds with 9 queries, spending 0.0077266693115234 doing MySQL queries and 0.061653137207031 doing PHP things.
