Time Before: 0.02185 seconds
Time After: 0.02680 seconds
Time Taken: 0.00495 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02691 seconds
Time After: 0.02740 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02775 seconds
Time After: 0.02793 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02882 seconds
Time After: 0.03142 seconds
Time Taken: 0.00260 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02801 seconds
Time After: 0.03562 seconds
Time Taken: 0.00761 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03939 seconds
Time After: 0.03962 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04142 seconds
Time After: 0.04264 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03868 seconds
Time After: 0.04285 seconds
Time Taken: 0.00417 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08034 seconds
Time After: 0.08052 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.62283 seconds
Time After: 0.62444 seconds
Time Taken: 0.00161 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.66333 seconds
Time After: 0.66352 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.67146 seconds
Time After: 0.67300 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773206789, location = '/forums/private.php?do=newpm&explain=1&u=108386', badlocation = 1 WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.70489 seconds
Time After: 0.70518 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
