Time Before: 0.00262 seconds
Time After: 0.00373 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00380 seconds
Time After: 0.00463 seconds
Time Taken: 0.00082 seconds
Time Before: 0.00483 seconds
Time After: 0.00497 seconds
Time Before: 0.00573 seconds
Time After: 0.00932 seconds
Time Taken: 0.00359 seconds
Time Before: 0.00502 seconds
Time After: 0.01325 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01574 seconds
Time After: 0.01621 seconds
Time Before: 0.02005 seconds
Time After: 0.02126 seconds
Time Before: 0.01498 seconds
Time After: 0.02144 seconds
Time Taken: 0.00646 seconds
Time Before: 0.02755 seconds
Time After: 0.02769 seconds
Time Before: 0.02950 seconds
Time After: 0.03079 seconds
Time Before: 0.03443 seconds
Time After: 0.03458 seconds
Time Before: 0.03663 seconds
Time After: 0.03836 seconds
Time Taken: 0.00173 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108409', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05078 seconds
Time After: 0.05121 seconds
