Time Before: 0.00153 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00249 seconds
Time Before: 0.00273 seconds
Time After: 0.00286 seconds
Time Before: 0.00379 seconds
Time After: 0.00597 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00294 seconds
Time After: 0.00932 seconds
Time Taken: 0.00638 seconds
Time Before: 0.01125 seconds
Time After: 0.01167 seconds
Time Before: 0.01314 seconds
Time After: 0.01434 seconds
Time Before: 0.01064 seconds
Time After: 0.01458 seconds
Time Taken: 0.00394 seconds
Time Before: 0.02143 seconds
Time After: 0.02163 seconds
Time Before: 0.02384 seconds
Time After: 0.02508 seconds
End call of global.php: 0.027509927749634
Time Before: 0.02906 seconds
Time After: 0.02923 seconds
Time Before: 0.03215 seconds
Time After: 0.03360 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108435'
Time Before: 0.04915 seconds
Time After: 0.04946 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.048228025436401 seconds with 9 queries, spending 0.0077412128448486 doing MySQL queries and 0.040486812591553 doing PHP things.
