Time Before: 0.00146 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00271 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00297 seconds
Time After: 0.00311 seconds
Time Before: 0.00377 seconds
Time After: 0.00676 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00316 seconds
Time After: 0.01015 seconds
Time Taken: 0.00700 seconds
Time Before: 0.01216 seconds
Time After: 0.01270 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01528 seconds
Time After: 0.01650 seconds
Time Before: 0.01144 seconds
Time After: 0.01667 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02321 seconds
Time After: 0.02341 seconds
Time Before: 0.02547 seconds
Time After: 0.02678 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02969 seconds
Time After: 0.02987 seconds
Time Before: 0.03197 seconds
Time After: 0.03343 seconds
UPDATE session SET lastactivity = 1782927499, location = '/forums/private.php?do=newpm&explain=1&u=108452' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04573 seconds
Time After: 0.04609 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
