Time Before: 0.00138 seconds
Time After: 0.00193 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00200 seconds
Time After: 0.00267 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00294 seconds
Time After: 0.00304 seconds
Time Before: 0.00368 seconds
Time After: 0.00596 seconds
Time Taken: 0.00228 seconds
Time Before: 0.00310 seconds
Time After: 0.00934 seconds
Time Taken: 0.00625 seconds
Time Before: 0.01107 seconds
Time After: 0.01145 seconds
Time Before: 0.01406 seconds
Time After: 0.01520 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01049 seconds
Time After: 0.01537 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02036 seconds
Time After: 0.02047 seconds
Time Before: 0.02230 seconds
Time After: 0.02349 seconds
End call of global.php: 0.025142192840576
Time Before: 0.02627 seconds
Time After: 0.02642 seconds
Time Before: 0.02835 seconds
Time After: 0.02981 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108470', badlocation = 1
WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.04214 seconds
Time After: 0.04248 seconds
Page generated in 0.041203022003174 seconds with 9 queries, spending 0.0078606605529785 doing MySQL queries and 0.033342361450195 doing PHP things.
