Time Before: 0.02485 seconds
Time After: 0.03349 seconds
Time Taken: 0.00864 seconds
Time Before: 0.03359 seconds
Time After: 0.03404 seconds
Time Before: 0.03427 seconds
Time After: 0.03471 seconds
Time Before: 0.03564 seconds
Time After: 0.03819 seconds
Time Taken: 0.00254 seconds
Time Before: 0.03478 seconds
Time After: 0.04263 seconds
Time Taken: 0.00785 seconds
Time Before: 0.05266 seconds
Time After: 0.05308 seconds
Time Before: 0.05590 seconds
Time After: 0.05720 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05189 seconds
Time After: 0.05748 seconds
Time Taken: 0.00559 seconds
Memory After: 2,261.703 KB
Time Before: 0.08847 seconds
Time After: 0.08864 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11273 seconds
Time After: 0.11396 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12519 seconds
Time After: 0.12538 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12820 seconds
Time After: 0.12967 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108484', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15225 seconds
Time After: 0.15276 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.508 KB
