Time Before: 0.01161 seconds
Time After: 0.01607 seconds
Time Taken: 0.00446 seconds
Time Before: 0.01614 seconds
Time After: 0.01653 seconds
Time Before: 0.01677 seconds
Time After: 0.01691 seconds
Time Before: 0.01766 seconds
Time After: 0.02004 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01698 seconds
Time After: 0.02397 seconds
Time Taken: 0.00699 seconds
Time Before: 0.03078 seconds
Time After: 0.03111 seconds
Time Before: 0.03245 seconds
Time After: 0.03361 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03007 seconds
Time After: 0.03380 seconds
Time Taken: 0.00373 seconds
Time Before: 0.05435 seconds
Time After: 0.05449 seconds
Time Before: 0.06596 seconds
Time After: 0.06733 seconds
Time Taken: 0.00137 seconds
Time Before: 0.07720 seconds
Time After: 0.07737 seconds
Time Before: 0.08013 seconds
Time After: 0.08159 seconds
UPDATE session SET lastactivity = 1776651687, location = '/forums/private.php?do=newpm&explain=1&u=108518' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.10166 seconds
Time After: 0.10200 seconds
