Time Before: 0.00178 seconds
Time After: 0.00229 seconds
Time Before: 0.00236 seconds
Time After: 0.00283 seconds
Time Before: 0.00340 seconds
Time After: 0.00367 seconds
Time Before: 0.00473 seconds
Time After: 0.00688 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00377 seconds
Time After: 0.01139 seconds
Time Taken: 0.00762 seconds
Time Before: 0.01370 seconds
Time After: 0.01408 seconds
Time Before: 0.01642 seconds
Time After: 0.01847 seconds
Time Taken: 0.00204 seconds
Time Before: 0.01294 seconds
Time After: 0.01872 seconds
Time Taken: 0.00578 seconds
Time Before: 0.02521 seconds
Time After: 0.02537 seconds
Time Before: 0.02719 seconds
Time After: 0.02871 seconds
Time Taken: 0.00152 seconds
Time Before: 0.03168 seconds
Time After: 0.03183 seconds
Time Before: 0.03388 seconds
Time After: 0.03533 seconds
UPDATE session SET lastactivity = 1789104683, location = '/forums/private.php?do=newpm&explain=1&u=108531', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04827 seconds
Time After: 0.04860 seconds
