Time Before: 0.01168 seconds
Time After: 0.01480 seconds
Time Taken: 0.00312 seconds
Time Before: 0.01491 seconds
Time After: 0.01529 seconds
Time Before: 0.01557 seconds
Time After: 0.01572 seconds
Time Before: 0.01663 seconds
Time After: 0.01888 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01580 seconds
Time After: 0.02323 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02805 seconds
Time After: 0.02831 seconds
Time Before: 0.03095 seconds
Time After: 0.03213 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02720 seconds
Time After: 0.03236 seconds
Time Taken: 0.00516 seconds
Time Before: 0.05058 seconds
Time After: 0.05078 seconds
Time Before: 0.05826 seconds
Time After: 0.05956 seconds
End call of global.php: 0.062252998352051
Time Before: 0.06718 seconds
Time After: 0.06739 seconds
Time Before: 0.06959 seconds
Time After: 0.07108 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108557', badlocation = 1
Time Before: 0.09124 seconds
Time After: 0.09156 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.090175867080688 seconds with 9 queries, spending 0.0077521800994873 doing MySQL queries and 0.082423686981201 doing PHP things.
