Time Before: 0.00208 seconds
Time After: 0.00267 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00274 seconds
Time After: 0.00310 seconds
Time Before: 0.00330 seconds
Time After: 0.00340 seconds
Time Before: 0.00397 seconds
Time After: 0.00615 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00345 seconds
Time After: 0.01103 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01286 seconds
Time After: 0.01305 seconds
Time Before: 0.01438 seconds
Time After: 0.01566 seconds
Time Before: 0.01226 seconds
Time After: 0.01596 seconds
Time Taken: 0.00370 seconds
Time Before: 0.02195 seconds
Time After: 0.02219 seconds
Time Before: 0.02495 seconds
Time After: 0.02623 seconds
End call of global.php: 0.029376029968262
Time Before: 0.03079 seconds
Time After: 0.03100 seconds
Time Before: 0.03445 seconds
Time After: 0.03600 seconds
Time Taken: 0.00155 seconds
SET lastactivity = 1773357913, location = '/forums/private.php?do=newpm&explain=1&u=108581', badlocation = 1
Time Before: 0.05650 seconds
Time After: 0.05686 seconds
Page generated in 0.05523419380188 seconds with 9 queries, spending 0.0077619552612305 doing MySQL queries and 0.047472238540649 doing PHP things.
