Time Before: 0.01712 seconds
Time After: 0.02267 seconds
Time Taken: 0.00555 seconds
Memory Before: 1,159.977 KB
Memory After: 1,185.094 KB
Time Before: 0.02283 seconds
Time After: 0.02431 seconds
Memory Before: 1,185.031 KB
Memory After: 1,186.039 KB
Time Before: 0.02477 seconds
Time After: 0.02498 seconds
Memory Before: 1,186.625 KB
Memory After: 1,187.148 KB
Time Before: 0.02633 seconds
Time After: 0.02955 seconds
Time Taken: 0.00322 seconds
Memory Before: 1,189.750 KB
Memory After: 1,190.672 KB
Time Before: 0.02506 seconds
Time After: 0.03414 seconds
Time Taken: 0.00908 seconds
Memory Before: 1,186.367 KB
Memory After: 2,267.375 KB
Time Before: 0.04136 seconds
Time After: 0.04158 seconds
Time Before: 0.04452 seconds
Time After: 0.04570 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04055 seconds
Time After: 0.04610 seconds
Memory After: 2,885.227 KB
Memory Used: 132.898 KB
Time Before: 0.06875 seconds
Time After: 0.06892 seconds
Memory Before: 3,438.344 KB
Memory After: 3,438.859 KB
Time Before: 0.40606 seconds
Time After: 0.40760 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,526.039 KB
Memory After: 3,526.633 KB
End call of global.php: 0.4105589389801
Time Before: 0.41883 seconds
Time After: 0.41898 seconds
Memory Before: 4,163.938 KB
Memory After: 4,164.367 KB
Time Before: 0.42171 seconds
Time After: 0.42336 seconds
Time Taken: 0.00165 seconds
Memory Before: 4,445.500 KB
Memory After: 4,447.188 KB
SET lastactivity = 1780632628, location = '/forums/private.php?do=newpm&explain=1&u=108588'
Time Before: 0.44307 seconds
Time After: 0.44331 seconds
Memory Before: 4,911.156 KB
Memory After: 4,911.383 KB
Page generated in 0.44183492660522 seconds with 9 queries, spending 0.010053873062134 doing MySQL queries and 0.43178105354309 doing PHP things.
