Time Before: 0.00758 seconds
Time After: 0.01231 seconds
Time Taken: 0.00473 seconds
Time Before: 0.01243 seconds
Time After: 0.01289 seconds
Time Before: 0.01320 seconds
Time After: 0.01340 seconds
Time Before: 0.01421 seconds
Time After: 0.01672 seconds
Time Taken: 0.00251 seconds
Time Before: 0.01348 seconds
Time After: 0.02085 seconds
Time Taken: 0.00737 seconds
Time Before: 0.02642 seconds
Time After: 0.02680 seconds
Time Before: 0.02935 seconds
Time After: 0.03050 seconds
Time Taken: 0.00115 seconds
Time Before: 0.02551 seconds
Time After: 0.03072 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05118 seconds
Time After: 0.05134 seconds
Time Before: 0.05983 seconds
Time After: 0.06104 seconds
Time Before: 0.06731 seconds
Time After: 0.06748 seconds
Time Before: 0.06998 seconds
Time After: 0.07143 seconds
UPDATE session SET lastactivity = 1784878182, location = '/forums/private.php?do=newpm&explain=1&u=108594', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.08741 seconds
Time After: 0.08767 seconds
