Time Before: 0.00128 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00229 seconds
Time Before: 0.00257 seconds
Time After: 0.00270 seconds
Time Before: 0.00348 seconds
Time After: 0.00613 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00279 seconds
Time After: 0.01073 seconds
Time Taken: 0.00794 seconds
Time Before: 0.01308 seconds
Time After: 0.01357 seconds
Time Before: 0.01600 seconds
Time After: 0.01723 seconds
Time Before: 0.01233 seconds
Time After: 0.01740 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02330 seconds
Time After: 0.02348 seconds
Time Before: 0.02565 seconds
Time After: 0.02689 seconds
End call of global.php: 0.028533935546875
Time Before: 0.02964 seconds
Time After: 0.02984 seconds
Time Before: 0.03182 seconds
Time After: 0.03325 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108604'
Time Before: 0.04588 seconds
Time After: 0.04638 seconds
Page generated in 0.044963836669922 seconds with 9 queries, spending 0.0084736347198486 doing MySQL queries and 0.036490201950073 doing PHP things.
