Time Before: 0.00142 seconds
Time After: 0.00187 seconds
Time Before: 0.00193 seconds
Time After: 0.00248 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00271 seconds
Time After: 0.00283 seconds
Time Before: 0.00356 seconds
Time After: 0.00620 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00288 seconds
Time After: 0.00960 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01137 seconds
Time After: 0.01179 seconds
Time Before: 0.01514 seconds
Time After: 0.01635 seconds
Time Before: 0.01073 seconds
Time After: 0.01652 seconds
Time Taken: 0.00578 seconds
Time Before: 0.02146 seconds
Time After: 0.02159 seconds
Time Before: 0.02347 seconds
Time After: 0.02468 seconds
End call of global.php: 0.026292085647583
Time Before: 0.02825 seconds
Time After: 0.02842 seconds
Time Before: 0.03112 seconds
Time After: 0.03260 seconds
SET lastactivity = 1788923045, location = '/forums/private.php?do=newpm&explain=1&u=10862'
Time Before: 0.04488 seconds
Time After: 0.04516 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.043982028961182 seconds with 9 queries, spending 0.0081961154937744 doing MySQL queries and 0.035785913467407 doing PHP things.
