Time Before: 0.00146 seconds
Time After: 0.00205 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00212 seconds
Time After: 0.00253 seconds
Time Before: 0.00286 seconds
Time After: 0.00302 seconds
Time Before: 0.00374 seconds
Time After: 0.00671 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00307 seconds
Time After: 0.01005 seconds
Time Taken: 0.00698 seconds
Time Before: 0.01179 seconds
Time After: 0.01220 seconds
Time Before: 0.01445 seconds
Time After: 0.01575 seconds
Time Before: 0.01124 seconds
Time After: 0.01593 seconds
Time Taken: 0.00469 seconds
Time Before: 0.02080 seconds
Time After: 0.02101 seconds
Time Before: 0.02327 seconds
Time After: 0.02517 seconds
Time Taken: 0.00190 seconds
End call of global.php: 0.026774168014526
Time Before: 0.02798 seconds
Time After: 0.02815 seconds
Time Before: 0.03012 seconds
Time After: 0.03156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108626'
Time Before: 0.04377 seconds
Time After: 0.04413 seconds
Page generated in 0.042898178100586 seconds with 9 queries, spending 0.0093569755554199 doing MySQL queries and 0.033541202545166 doing PHP things.
