Time Before: 0.00787 seconds
Time After: 0.01014 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01027 seconds
Time After: 0.01073 seconds
Time Before: 0.01098 seconds
Time After: 0.01111 seconds
Time Before: 0.01197 seconds
Time After: 0.01461 seconds
Time Taken: 0.00264 seconds
Time Before: 0.01119 seconds
Time After: 0.01857 seconds
Time Taken: 0.00738 seconds
Time Before: 0.02259 seconds
Time After: 0.02299 seconds
Time Before: 0.02553 seconds
Time After: 0.02676 seconds
Time Before: 0.02190 seconds
Time After: 0.02696 seconds
Time Taken: 0.00506 seconds
Time Before: 0.04211 seconds
Time After: 0.04226 seconds
Time Before: 0.05057 seconds
Time After: 0.05179 seconds
Time Before: 0.05625 seconds
Time After: 0.05641 seconds
Time Before: 0.05878 seconds
Time After: 0.06030 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108639' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.07700 seconds
Time After: 0.07743 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
