Time Before: 0.00271 seconds
Time After: 0.00353 seconds
Time Taken: 0.00082 seconds
Time Before: 0.00365 seconds
Time After: 0.00447 seconds
Time Before: 0.00487 seconds
Time After: 0.00511 seconds
Time Before: 0.00581 seconds
Time After: 0.00858 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00518 seconds
Time After: 0.01201 seconds
Time Taken: 0.00682 seconds
Time Before: 0.01414 seconds
Time After: 0.01467 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01737 seconds
Time After: 0.01864 seconds
Time Before: 0.01348 seconds
Time After: 0.01881 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02588 seconds
Time After: 0.02610 seconds
Time Before: 0.02798 seconds
Time After: 0.02927 seconds
Time Before: 0.03214 seconds
Time After: 0.03229 seconds
Time Before: 0.03483 seconds
Time After: 0.03657 seconds
Time Taken: 0.00174 seconds
UPDATE session SET lastactivity = 1789016448, location = '/forums/private.php?do=newpm&explain=1&u=108648' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04887 seconds
Time After: 0.04921 seconds
