Time Before: 0.02317 seconds
Time After: 0.03304 seconds
Time Taken: 0.00987 seconds
Time Before: 0.03312 seconds
Time After: 0.03360 seconds
Time Before: 0.03381 seconds
Time After: 0.03396 seconds
Time Before: 0.03470 seconds
Time After: 0.03697 seconds
Time Taken: 0.00227 seconds
Time Before: 0.03402 seconds
Time After: 0.04115 seconds
Time Taken: 0.00713 seconds
Time Before: 0.04825 seconds
Time After: 0.04874 seconds
Time Before: 0.05130 seconds
Time After: 0.05254 seconds
Time Before: 0.04752 seconds
Time After: 0.05278 seconds
Time Taken: 0.00526 seconds
Time Before: 0.10230 seconds
Time After: 0.10268 seconds
Time Before: 0.12181 seconds
Time After: 0.12316 seconds
Time Taken: 0.00135 seconds
Time Before: 0.13624 seconds
Time After: 0.13641 seconds
Time Before: 0.13860 seconds
Time After: 0.14004 seconds
UPDATE session SET lastactivity = 1784822553, location = '/forums/private.php?do=newpm&explain=1&u=108705' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.15656 seconds
Time After: 0.15683 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
