Time Before: 0.00157 seconds
Time After: 0.00212 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00219 seconds
Time After: 0.00258 seconds
Time Before: 0.00278 seconds
Time After: 0.00295 seconds
Time Before: 0.00378 seconds
Time After: 0.00650 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00303 seconds
Time After: 0.00987 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01155 seconds
Time After: 0.01191 seconds
Time Before: 0.01441 seconds
Time After: 0.01560 seconds
Time Before: 0.01100 seconds
Time After: 0.01578 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02080 seconds
Time After: 0.02097 seconds
Time Before: 0.02271 seconds
Time After: 0.02398 seconds
Time Before: 0.02697 seconds
Time After: 0.02714 seconds
Time Before: 0.02912 seconds
Time After: 0.03053 seconds
UPDATE session SET lastactivity = 1788973225, location = '/forums/private.php?do=newpm&explain=1&u=108729' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04293 seconds
Time After: 0.04316 seconds
