Time Before: 0.01561 seconds
Time After: 0.02455 seconds
Time Taken: 0.00894 seconds
Time Before: 0.02465 seconds
Time After: 0.02515 seconds
Time Before: 0.02542 seconds
Time After: 0.02556 seconds
Time Before: 0.02659 seconds
Time After: 0.02913 seconds
Time Taken: 0.00254 seconds
Time Before: 0.02565 seconds
Time After: 0.03423 seconds
Time Taken: 0.00857 seconds
Time Before: 0.04164 seconds
Time After: 0.04205 seconds
Time Before: 0.04469 seconds
Time After: 0.04591 seconds
Time Before: 0.04079 seconds
Time After: 0.04618 seconds
Time Taken: 0.00538 seconds
Time Before: 0.07856 seconds
Time After: 0.07872 seconds
Time Before: 0.09362 seconds
Time After: 0.09488 seconds
Time Before: 0.10182 seconds
Time After: 0.10198 seconds
Time Before: 0.10459 seconds
Time After: 0.10611 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1785276034, location = '/forums/private.php?do=newpm&explain=1&u=108745' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.12380 seconds
Time After: 0.12410 seconds
