Time Before: 0.03072 seconds
Time After: 0.04254 seconds
Time Taken: 0.01183 seconds
Time Before: 0.04263 seconds
Time After: 0.04305 seconds
Time Before: 0.04327 seconds
Time After: 0.04342 seconds
Time Before: 0.04425 seconds
Time After: 0.04635 seconds
Time Taken: 0.00209 seconds
Time Before: 0.04350 seconds
Time After: 0.05052 seconds
Time Taken: 0.00703 seconds
Time Before: 0.06290 seconds
Time After: 0.06333 seconds
Time Before: 0.06470 seconds
Time After: 0.06590 seconds
Time Before: 0.06231 seconds
Time After: 0.06613 seconds
Time Taken: 0.00381 seconds
Time Before: 0.11302 seconds
Time After: 0.11316 seconds
Time Before: 0.14215 seconds
Time After: 0.14340 seconds
Time Before: 0.14982 seconds
Time After: 0.14997 seconds
Time Before: 0.15238 seconds
Time After: 0.15382 seconds
UPDATE session SET lastactivity = 1776698464, location = '/forums/private.php?do=newpm&explain=1&u=108752' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.17344 seconds
Time After: 0.17376 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
