Time Before: 0.00135 seconds
Time After: 0.00186 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00193 seconds
Time After: 0.00234 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00258 seconds
Time After: 0.00270 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00351 seconds
Time After: 0.00636 seconds
Time Taken: 0.00285 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00278 seconds
Time After: 0.00977 seconds
Time Taken: 0.00698 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01179 seconds
Time After: 0.01203 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01494 seconds
Time After: 0.01627 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01123 seconds
Time After: 0.01645 seconds
Time Taken: 0.00522 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02156 seconds
Time After: 0.02168 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02370 seconds
Time After: 0.02500 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
End call of global.php: 0.026650905609131
Time Before: 0.02798 seconds
Time After: 0.02813 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.03012 seconds
Time After: 0.03151 seconds
Time Taken: 0.00138 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
SET lastactivity = 1788987095, location = '/forums/private.php?do=newpm&explain=1&u=108765'
Time Before: 0.04376 seconds
Time After: 0.04444 seconds
Time Taken: 0.00068 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
Page generated in 0.042902946472168 seconds with 9 queries, spending 0.0085737705230713 doing MySQL queries and 0.034329175949097 doing PHP things.
