Time Before: 0.00151 seconds
Time After: 0.00203 seconds
Time Before: 0.00209 seconds
Time After: 0.00251 seconds
Time Before: 0.00278 seconds
Time After: 0.00294 seconds
Time Before: 0.00385 seconds
Time After: 0.00615 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00302 seconds
Time After: 0.01138 seconds
Time Taken: 0.00836 seconds
Time Before: 0.01460 seconds
Time After: 0.01502 seconds
Time Before: 0.01805 seconds
Time After: 0.01970 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01383 seconds
Time After: 0.01990 seconds
Time Taken: 0.00608 seconds
Memory After: 2,261.820 KB
Time Before: 0.02631 seconds
Time After: 0.02646 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 2.19620 seconds
Time After: 2.19848 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 2.20728 seconds
Time After: 2.20749 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 2.21033 seconds
Time After: 2.21192 seconds
Time Taken: 0.00159 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788987826, location = '/forums/private.php?do=newpm&explain=1&u=108784', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 2.22973 seconds
Time After: 2.23006 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
