Time Before: 0.01704 seconds
Time After: 0.02249 seconds
Time Taken: 0.00545 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02259 seconds
Time After: 0.02312 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02339 seconds
Time After: 0.02351 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02439 seconds
Time After: 0.02728 seconds
Time Taken: 0.00289 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02360 seconds
Time After: 0.03279 seconds
Time Taken: 0.00919 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03973 seconds
Time After: 0.03991 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04209 seconds
Time After: 0.04343 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03902 seconds
Time After: 0.04372 seconds
Time Taken: 0.00470 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07096 seconds
Time After: 0.07109 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 2.46336 seconds
Time After: 2.46502 seconds
Time Taken: 0.00166 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 2.51566 seconds
Time After: 2.51594 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 2.52841 seconds
Time After: 2.53002 seconds
Time Taken: 0.00160 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772953707, location = '/forums/private.php?do=newpm&explain=1&u=108790', badlocation = 1 WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 2.56918 seconds
Time After: 2.56946 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
