Time Before: 0.01179 seconds
Time After: 0.01519 seconds
Time Taken: 0.00341 seconds
Time Before: 0.01529 seconds
Time After: 0.01576 seconds
Time Before: 0.01601 seconds
Time After: 0.01614 seconds
Time Before: 0.01692 seconds
Time After: 0.01911 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01620 seconds
Time After: 0.02338 seconds
Time Taken: 0.00718 seconds
Time Before: 0.02840 seconds
Time After: 0.02887 seconds
Time Before: 0.03030 seconds
Time After: 0.03146 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02767 seconds
Time After: 0.03165 seconds
Time Taken: 0.00398 seconds
Memory After: 2,261.836 KB
Time Before: 0.04984 seconds
Time After: 0.04998 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05993 seconds
Time After: 0.06117 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.06633 seconds
Time After: 0.06646 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06847 seconds
Time After: 0.06987 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788918713, location = '/forums/private.php?do=newpm&explain=1&u=10883' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08376 seconds
Time After: 0.08404 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
