Time Before: 0.00354 seconds
Time After: 0.00429 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00437 seconds
Time After: 0.00477 seconds
Time Before: 0.00503 seconds
Time After: 0.00517 seconds
Time Before: 0.00600 seconds
Time After: 0.00891 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00526 seconds
Time After: 0.01453 seconds
Time Taken: 0.00928 seconds
Time Before: 0.01701 seconds
Time After: 0.01744 seconds
Time Before: 0.01910 seconds
Time After: 0.02039 seconds
Time Before: 0.01623 seconds
Time After: 0.02065 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02808 seconds
Time After: 0.02822 seconds
Time Before: 0.03047 seconds
Time After: 0.03175 seconds
Time Before: 0.03468 seconds
Time After: 0.03484 seconds
Time Before: 0.03766 seconds
Time After: 0.03910 seconds
UPDATE session SET lastactivity = 1784885789, location = '/forums/private.php?do=newpm&explain=1&u=108842', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.05393 seconds
Time After: 0.05424 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
