Time Before: 0.00140 seconds
Time After: 0.00185 seconds
Time Before: 0.00193 seconds
Time After: 0.00244 seconds
Time Before: 0.00273 seconds
Time After: 0.00285 seconds
Time Before: 0.00375 seconds
Time After: 0.00629 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00293 seconds
Time After: 0.01079 seconds
Time Taken: 0.00786 seconds
Time Before: 0.01254 seconds
Time After: 0.01343 seconds
Time Taken: 0.00090 seconds
Time Before: 0.01557 seconds
Time After: 0.01675 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01197 seconds
Time After: 0.01698 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02198 seconds
Time After: 0.02207 seconds
Time Taken: 0.00009 seconds
Time Before: 0.02384 seconds
Time After: 0.02503 seconds
Time Before: 0.02768 seconds
Time After: 0.02779 seconds
Time Before: 0.02964 seconds
Time After: 0.03102 seconds
Time Taken: 0.00138 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108879' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04335 seconds
Time After: 0.04359 seconds
