Time Before: 0.00141 seconds
Time After: 0.00195 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00202 seconds
Time After: 0.00251 seconds
Time Before: 0.00274 seconds
Time After: 0.00289 seconds
Time Before: 0.00377 seconds
Time After: 0.00614 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00297 seconds
Time After: 0.01133 seconds
Time Taken: 0.00836 seconds
Time Before: 0.01391 seconds
Time After: 0.01430 seconds
Time Before: 0.01679 seconds
Time After: 0.01798 seconds
Time Before: 0.01318 seconds
Time After: 0.01817 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02360 seconds
Time After: 0.02376 seconds
Time Before: 0.02554 seconds
Time After: 0.02679 seconds
Time Before: 0.02964 seconds
Time After: 0.02979 seconds
Time Before: 0.03190 seconds
Time After: 0.03340 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108894', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04714 seconds
Time After: 0.04742 seconds
