Time Before: 0.00201 seconds
Time After: 0.00269 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00278 seconds
Time After: 0.00333 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00361 seconds
Time After: 0.00377 seconds
Time Before: 0.00443 seconds
Time After: 0.00702 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00382 seconds
Time After: 0.01055 seconds
Time Taken: 0.00673 seconds
Time Before: 0.01239 seconds
Time After: 0.01283 seconds
Time Before: 0.01559 seconds
Time After: 0.01679 seconds
Time Before: 0.01177 seconds
Time After: 0.01696 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02219 seconds
Time After: 0.02232 seconds
Time Before: 0.02418 seconds
Time After: 0.02544 seconds
End call of global.php: 0.027024030685425
Time Before: 0.02838 seconds
Time After: 0.02852 seconds
Time Before: 0.03042 seconds
Time After: 0.03186 seconds
SET lastactivity = 1784887397, location = '/forums/private.php?do=newpm&explain=1&u=108901'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04594 seconds
Time After: 0.04621 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.045046091079712 seconds with 9 queries, spending 0.0081667900085449 doing MySQL queries and 0.036879301071167 doing PHP things.
