Time Before: 0.02362 seconds
Time After: 0.03177 seconds
Time Taken: 0.00815 seconds
Time Before: 0.03187 seconds
Time After: 0.03240 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03272 seconds
Time After: 0.03315 seconds
Time Before: 0.03430 seconds
Time After: 0.03666 seconds
Time Taken: 0.00236 seconds
Time Before: 0.03323 seconds
Time After: 0.04134 seconds
Time Taken: 0.00811 seconds
Time Before: 0.05016 seconds
Time After: 0.05060 seconds
Time Before: 0.05314 seconds
Time After: 0.05435 seconds
Time Before: 0.04945 seconds
Time After: 0.05452 seconds
Time Taken: 0.00507 seconds
Time Before: 0.09931 seconds
Time After: 0.09947 seconds
Time Before: 0.11986 seconds
Time After: 0.12129 seconds
Time Before: 0.13221 seconds
Time After: 0.13237 seconds
Time Before: 0.13592 seconds
Time After: 0.13760 seconds
Time Taken: 0.00167 seconds
UPDATE session SET lastactivity = 1788962070, location = '/forums/private.php?do=newpm&explain=1&u=10892', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15620 seconds
Time After: 0.15654 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
