Time Before: 0.00196 seconds
Time After: 0.00263 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00273 seconds
Time After: 0.00317 seconds
Time Before: 0.00342 seconds
Time After: 0.00362 seconds
Time Before: 0.00459 seconds
Time After: 0.00736 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00370 seconds
Time After: 0.01285 seconds
Time Taken: 0.00915 seconds
Time Before: 0.01534 seconds
Time After: 0.01577 seconds
Time Before: 0.01898 seconds
Time After: 0.02023 seconds
Time Before: 0.01456 seconds
Time After: 0.02051 seconds
Time Taken: 0.00595 seconds
Time Before: 0.02770 seconds
Time After: 0.02796 seconds
Time Before: 0.02997 seconds
Time After: 0.03125 seconds
End call of global.php: 0.032953977584839
Time Before: 0.03433 seconds
Time After: 0.03447 seconds
Time Before: 0.03674 seconds
Time After: 0.03822 seconds
SET lastactivity = 1783181828, location = '/forums/private.php?do=newpm&explain=1&u=108938'
Time Before: 0.05482 seconds
Time After: 0.05516 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.053536891937256 seconds with 9 queries, spending 0.0085995197296143 doing MySQL queries and 0.044937372207642 doing PHP things.
