Time Before: 0.02237 seconds
Time After: 0.03105 seconds
Time Taken: 0.00868 seconds
Time Before: 0.03116 seconds
Time After: 0.03169 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03193 seconds
Time After: 0.03204 seconds
Time Before: 0.03280 seconds
Time After: 0.03508 seconds
Time Taken: 0.00228 seconds
Time Before: 0.03211 seconds
Time After: 0.03916 seconds
Time Taken: 0.00704 seconds
Time Before: 0.05024 seconds
Time After: 0.05067 seconds
Time Before: 0.05203 seconds
Time After: 0.05330 seconds
Time Before: 0.04957 seconds
Time After: 0.05354 seconds
Time Taken: 0.00397 seconds
Time Before: 0.09813 seconds
Time After: 0.09830 seconds
Time Before: 0.12111 seconds
Time After: 0.12234 seconds
Time Before: 0.13809 seconds
Time After: 0.13834 seconds
Time Before: 0.14101 seconds
Time After: 0.14248 seconds
UPDATE session SET lastactivity = 1776716575, location = '/forums/private.php?do=newpm&explain=1&u=108940' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.16140 seconds
Time After: 0.16175 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
