Time Before: 0.00230 seconds
Time After: 0.00282 seconds
Time Before: 0.00289 seconds
Time After: 0.00359 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00388 seconds
Time After: 0.00401 seconds
Time Before: 0.00496 seconds
Time After: 0.00754 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00406 seconds
Time After: 0.01188 seconds
Time Taken: 0.00781 seconds
Time Before: 0.01391 seconds
Time After: 0.01433 seconds
Time Before: 0.01702 seconds
Time After: 0.01911 seconds
Time Taken: 0.00209 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01331 seconds
Time After: 0.01936 seconds
Time Taken: 0.00605 seconds
Memory After: 2,261.703 KB
Time Before: 0.02607 seconds
Time After: 0.02620 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02822 seconds
Time After: 0.02949 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.031273126602173
Time Before: 0.03262 seconds
Time After: 0.03279 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03571 seconds
Time After: 0.03759 seconds
Time Taken: 0.00188 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=108942'
Time Before: 0.05113 seconds
Time After: 0.05151 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.050204038619995 seconds with 9 queries, spending 0.0097315311431885 doing MySQL queries and 0.040472507476807 doing PHP things.
