Time Before: 0.00879 seconds
Time After: 0.01209 seconds
Time Taken: 0.00330 seconds
Time Before: 0.01224 seconds
Time After: 0.01276 seconds
Time Before: 0.01304 seconds
Time After: 0.01321 seconds
Time Before: 0.01397 seconds
Time After: 0.01654 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01328 seconds
Time After: 0.02094 seconds
Time Taken: 0.00767 seconds
Time Before: 0.02642 seconds
Time After: 0.02680 seconds
Time Before: 0.02828 seconds
Time After: 0.02950 seconds
Time Before: 0.02569 seconds
Time After: 0.02975 seconds
Time Taken: 0.00406 seconds
Time Before: 0.04522 seconds
Time After: 0.04536 seconds
Time Before: 0.05380 seconds
Time After: 0.05502 seconds
Time Before: 0.06136 seconds
Time After: 0.06150 seconds
Time Before: 0.06406 seconds
Time After: 0.06554 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108961', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.08310 seconds
Time After: 0.08334 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
