Time Before: 0.02397 seconds
Time After: 0.03070 seconds
Time Taken: 0.00673 seconds
Time Before: 0.03082 seconds
Time After: 0.03138 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03162 seconds
Time After: 0.03175 seconds
Time Before: 0.03249 seconds
Time After: 0.03485 seconds
Time Taken: 0.00236 seconds
Time Before: 0.03181 seconds
Time After: 0.03915 seconds
Time Taken: 0.00734 seconds
Time Before: 0.05160 seconds
Time After: 0.05185 seconds
Time Before: 0.05413 seconds
Time After: 0.05532 seconds
Time Before: 0.05095 seconds
Time After: 0.05555 seconds
Time Taken: 0.00460 seconds
Time Before: 0.09845 seconds
Time After: 0.09866 seconds
Time Before: 0.33399 seconds
Time After: 0.33542 seconds
Time Before: 0.34744 seconds
Time After: 0.34766 seconds
Time Before: 0.35036 seconds
Time After: 0.35211 seconds
Time Taken: 0.00175 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108978', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.37026 seconds
Time After: 0.37052 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
