Time Before: 0.00134 seconds
Time After: 0.00192 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00199 seconds
Time After: 0.00241 seconds
Time Before: 0.00261 seconds
Time After: 0.00279 seconds
Time Before: 0.00363 seconds
Time After: 0.00764 seconds
Time Taken: 0.00401 seconds
Time Before: 0.00284 seconds
Time After: 0.01147 seconds
Time Taken: 0.00863 seconds
Time Before: 0.01323 seconds
Time After: 0.01363 seconds
Time Before: 0.01622 seconds
Time After: 0.01747 seconds
Time Before: 0.01261 seconds
Time After: 0.01766 seconds
Time Taken: 0.00505 seconds
Time Before: 0.02323 seconds
Time After: 0.02338 seconds
Time Before: 0.02520 seconds
Time After: 0.02645 seconds
Time Before: 0.03046 seconds
Time After: 0.03063 seconds
Time Before: 0.03274 seconds
Time After: 0.03429 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109032' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04800 seconds
Time After: 0.04824 seconds
