Time Before: 0.00163 seconds
Time After: 0.00238 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00245 seconds
Time After: 0.00375 seconds
Time Before: 0.00456 seconds
Time After: 0.00526 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00610 seconds
Time After: 0.00919 seconds
Time Taken: 0.00309 seconds
Time Before: 0.00533 seconds
Time After: 0.01264 seconds
Time Taken: 0.00730 seconds
Time Before: 0.01476 seconds
Time After: 0.01511 seconds
Time Before: 0.01752 seconds
Time After: 0.01872 seconds
Time Before: 0.01413 seconds
Time After: 0.01889 seconds
Time Taken: 0.00476 seconds
Time Before: 0.02684 seconds
Time After: 0.02698 seconds
Time Before: 0.02966 seconds
Time After: 0.03095 seconds
Time Before: 0.03513 seconds
Time After: 0.03533 seconds
Time Before: 0.03879 seconds
Time After: 0.04024 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109045', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05740 seconds
Time After: 0.05775 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
