Time Before: 0.00136 seconds
Time After: 0.00214 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00221 seconds
Time After: 0.00278 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00305 seconds
Time After: 0.00318 seconds
Time Before: 0.00391 seconds
Time After: 0.00655 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00323 seconds
Time After: 0.00996 seconds
Time Taken: 0.00673 seconds
Time Before: 0.01170 seconds
Time After: 0.01217 seconds
Time Before: 0.01368 seconds
Time After: 0.01487 seconds
Time Before: 0.01112 seconds
Time After: 0.01504 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02000 seconds
Time After: 0.02013 seconds
Time Before: 0.02189 seconds
Time After: 0.02313 seconds
Time Before: 0.02592 seconds
Time After: 0.02605 seconds
Time Before: 0.02800 seconds
Time After: 0.02948 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109085' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04173 seconds
Time After: 0.04199 seconds
