Time Before: 0.00921 seconds
Time After: 0.01224 seconds
Time Taken: 0.00303 seconds
Time Before: 0.01235 seconds
Time After: 0.01270 seconds
Time Before: 0.01294 seconds
Time After: 0.01305 seconds
Time Before: 0.01374 seconds
Time After: 0.01630 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01312 seconds
Time After: 0.02087 seconds
Time Taken: 0.00776 seconds
Time Before: 0.02701 seconds
Time After: 0.02743 seconds
Time Before: 0.03004 seconds
Time After: 0.03130 seconds
Time Before: 0.02637 seconds
Time After: 0.03152 seconds
Time Taken: 0.00516 seconds
Time Before: 0.04889 seconds
Time After: 0.04906 seconds
Time Before: 0.05933 seconds
Time After: 0.06058 seconds
End call of global.php: 0.063007116317749
Time Before: 0.06814 seconds
Time After: 0.06832 seconds
Time Before: 0.07094 seconds
Time After: 0.07345 seconds
Time Taken: 0.00251 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109087'
Time Before: 0.09273 seconds
Time After: 0.09307 seconds
Page generated in 0.091208934783936 seconds with 9 queries, spending 0.0091593265533447 doing MySQL queries and 0.082049608230591 doing PHP things.
