Time Before: 0.02091 seconds
Time After: 0.02798 seconds
Time Taken: 0.00707 seconds
Time Before: 0.02808 seconds
Time After: 0.02863 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02896 seconds
Time After: 0.02909 seconds
Time Before: 0.02983 seconds
Time After: 0.03285 seconds
Time Taken: 0.00302 seconds
Time Before: 0.02914 seconds
Time After: 0.03719 seconds
Time Taken: 0.00805 seconds
Time Before: 0.05029 seconds
Time After: 0.05067 seconds
Time Before: 0.05203 seconds
Time After: 0.05429 seconds
Time Taken: 0.00225 seconds
Time Before: 0.04959 seconds
Time After: 0.05450 seconds
Time Taken: 0.00492 seconds
Time Before: 0.07713 seconds
Time After: 0.07727 seconds
Time Before: 0.10309 seconds
Time After: 0.10433 seconds
Time Before: 0.12041 seconds
Time After: 0.12055 seconds
Time Before: 0.12355 seconds
Time After: 0.12497 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=109092', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.14751 seconds
Time After: 0.14778 seconds
