Time Before: 0.02336 seconds
Time After: 0.02892 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02899 seconds
Time After: 0.02938 seconds
Time Before: 0.02959 seconds
Time After: 0.02973 seconds
Time Before: 0.03059 seconds
Time After: 0.03286 seconds
Time Taken: 0.00227 seconds
Time Before: 0.02980 seconds
Time After: 0.03728 seconds
Time Taken: 0.00748 seconds
Time Before: 0.04992 seconds
Time After: 0.05016 seconds
Time Before: 0.05338 seconds
Time After: 0.05461 seconds
Time Before: 0.04928 seconds
Time After: 0.05483 seconds
Time Taken: 0.00555 seconds
Time Before: 0.08631 seconds
Time After: 0.08645 seconds
Time Before: 0.10375 seconds
Time After: 0.10496 seconds
End call of global.php: 0.10724210739136
Time Before: 0.11879 seconds
Time After: 0.11893 seconds
Time Before: 0.12149 seconds
Time After: 0.12296 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=109137', badlocation = 1
Time Before: 0.14165 seconds
Time After: 0.14221 seconds
Time Taken: 0.00057 seconds
Page generated in 0.14065217971802 seconds with 9 queries, spending 0.0078020095825195 doing MySQL queries and 0.1328501701355 doing PHP things.
